Home > Technical (L322) > Steering Column replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
the ignition is on the dash ,whats that to do with the steering column.. ... - .- -.
3rd Mar 2016 6:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
Well that's weird, didn't think that problem happened to a late one, recognised problem on the BMW FF's. I read that it was sorted when they facelifted...
3rd Mar 2016 6:03pm |
Bluestu33 Member Since: 31 Dec 2014 Location: Cambridgeshire Posts: 69 |
Stan - They just told me it was the locking solenoid that was failing and they cannot be replaced, so it has to be the whole steering column. |
3rd Mar 2016 6:07pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
failed ignition switch would seem the likely issue wouldnt it? You can paypal direct using - www.paypal.me/duckworthparts
3rd Mar 2016 6:18pm |
I will be speaking to the garage in more detail tomorrow, but they have said it is a module within the steering column that is causing the issue and only the whole steering column replacement can fix it.
3rd Mar 2016 6:35pm |
It's the steering lock solenoid that get's stuck on the early cars, it runs out of lube, dries up and stops moving, the 2mm hole is a bodge to get it working for a limited time, if the hole is drilled slightly wrong then it will damage the lock.
3rd Mar 2016 7:08pm |
Brilliant thanks, I will contact Craig tomorrow |
3rd Mar 2016 7:25pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
Hallo, the columns with the defect solenoid are inside until May 2009, had here a RR TDV8 from 2008 from switzerland (was transported on a trailer, because fuse 18 trick and dangerous hole for WD40 was limited time), build out the column, new solenoid fitted, new electronic fitted, client payment was 1.300 Euro, and was happy to drive back one day later on his own wheels..., best wishes, Uli TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
3rd Mar 2016 9:41pm |
I will be in Düsseldorf for 3 days in April, I'm quite tempted to drive over??? |
3rd Mar 2016 10:14pm |
You are welcome, sir....., please send PM to me, will answer of course. TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
4th Mar 2016 12:04am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I was lucky enough to pick up a near new column as a spare from a 2009 MY10 L322. Is this different to the column in a MY08 L322? Will it fit? Sorry if it's a high jack. ______________________________
4th Mar 2016 7:09am |
The Mod.10 are cheaper of course, because they have no mistakes, because new construction, look at the part number, and look in Google Pictures, you will see the difference TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
4th Mar 2016 7:37am |
And does the MY10 column fit? ______________________________
4th Mar 2016 8:09am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
How does the steering column lock stop the key from turning in the ignition, when it is only linked by wires? does not compute
4th Mar 2016 8:35am |
