Home > Maintenance & Mods (L322) > Central locking woirking on one side only
fogotter
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Hi Forum,
Hoping someone has some ideas. I have just bought a 2003 td6 range rover, the only issue is that the central locking only works on the drivers side. To open the doors on the nearside i have to go into the vehicle and use the handles from the inside.
My knowledge of these vehicles is limitied as ive only just got it. Does anyone have any ideas??
regards
Paul
Post #375440 3rd Mar 2016 8:24am
kbald
Have you tried pressing the button again once the drivers side is open? I know volkswagens used to or still do this when one press opens the drivers side and two to open all doors! No idea if this would be the case on yours but may be worth a try as it could be hat simple! Probably not though Rolling Eyes
Post #375441 3rd Mar 2016 8:34am
fogotter
Hi Kbald,
Thanks for the repsonse. I have tried that. If i press it once the drivers door opens. When i press it a second time the offside rear door opens but nothing from the nearside doors.
regards
Paul
Post #375446 3rd Mar 2016 9:22am
I presume they lock ok? My guess would be Both NS latches will have failed... The central locking motor is held within the latch Thumbs Up
They are not that much to replace or if outside your budget? There are plenty being broken sir Bow down Thumbs Up
Post #375449 3rd Mar 2016 9:33am
fogotter
Cheers Craig,
I will have a look at that.
regards
Paul
Post #375455 3rd Mar 2016 9:46am
You didn’t answer as to weather they lock or not sir? Whistle
Post #375461 3rd Mar 2016 10:16am
fogotter
Sorry Craig,
Yes they lock fine and when i doubkle click the key fob when opening the door "knob" pops up on the nearside doors, they just wont open with the outer handle.
regards
Paul
Post #375533 3rd Mar 2016 1:22pm
In that case, even more certain now sir... Definitely the door latch assemblies at fault... We do lots of them Rolling Eyes
Post #375644 4th Mar 2016 1:22am
fogotter
Thanks Craig,
Will get to it next week and let you know
regards
Paul
Post #375678 4th Mar 2016 11:38am
Your welcome sir... Thumbs Up
Post #375681 4th Mar 2016 11:51am
fogotter
Well my nearside door catches have arrived and I am poised to take off the door card.
Before I do can I just run it past you guys as to whether I need to do anything before hand, if I remove the door card is there an air bag going to blow me into next week? Is it just a case of remove the screws etc. and you get access to the door catches?
regards
Paul
Post #376662 10th Mar 2016 10:22am
If you disconnect the battery Paul, the airbag system is dead sir...
But yes, simply remove the door card, remove the latch & refit Thumbs Up
Post #376663 10th Mar 2016 10:35am
fogotter
Cheers Craig,
I think I will disconnect the battery, just to be on the safe side.
Thanks again for your advice
Regards
Paul
Post #376667 10th Mar 2016 11:11am
Post #376669 10th Mar 2016 11:45am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I had a similar issue when I installed new door handles. Only certain doors would unlock with others doing nothing.
I removed the central locking fuse and let the system reset. There is also a screw that calibrates the lock under a rubber bung on the door edge next to the lock. I undid it a few turns and then tightened it. Not sure it did anything but all four door locks sprang to life as normal!
Worth a shot if it is just a calibration thing. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #376673 10th Mar 2016 12:09pm
