![]() | Home > Technical (L322) > Is there more than one type of heated windscreen? |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Yes 02-05my has BMW plugs
| Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109
Thanks, it is making sense now. There are a pair of single pin connectors on each side on the A-pillar which are live when the heater is turned on, so these must be the feeds to the screen. The connection location must have changed as well as the connector type, it looks like an early screen has been fitted. To be fair to him the fitter is being very good, he has been back on to his suppliers and they are sorting out a new screen for early next week.
| sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185
I had my windscreen replaced this weekend - 1st attempt they brought the wrong screen - it was for the right model and year but had a different clip for the rain sensor - there are loads of different ones, but not as bad as the Volvo ones though. |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Its not just the actual physical connections but there are different acoustic values too what I did was get the original code from Landrover and this is what I got so plenty of room for variants
| Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190
Acoustic values??? What's all that about? Regards,
| lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513
were not all the screen the same austoic value? |
No... Mine has acoustic glass and it makes it a lot quieter than a like for like model without |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
I think you cannot upgrade to acoustic glass if your original car did not have it originally installed. Tom
| steptoe Member Since: 23 Jul 2012 Location: london Posts: 382
Don't forget there's also the solar reflective option. |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3963
According to the Autoglass man all Range Rover screens from Pilkington have acoustic glass on account of the fact that most are diesels which obviously make more engine noise but that may be |
'Bertha' - 2014 SDV8 Autobigraphy
