Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 6 of 12 <123 ... 567 ... 101112>
jasonr
United Kingdom 2008 Range Rover Autobiography 5.0 SC V8 Lucerne Green
Hi Matt,
Great job. I want to do this with my 2008 autobiography but have no mechanical experience. Can you, or anyone, recommend a person or company that will do this for me?
Post #375851 5th Mar 2016 2:09pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi to all.Upgrade from 04 to 10 after a week's efforts,due to lack of time and expertise,successfully completed thanks to site infos.
Only problem i have is that although sidelights/indicators/main/high beam are properly operate when i switch on headlights from time to time and not always appears the "check side lights" signal and once received "check headlights" signal.
I have not used any interface box but only the resistor for the indicators.
Any ideas how i can solve this problem?
Thanks
Post #376525 9th Mar 2016 1:06pm
AKIS
Any reply please Question
Post #376666 10th Mar 2016 10:44am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
If the lights seem to be working ok but you are getting check bulb/light messages it sounds like the cold (engine off) or hot (engine on) monitoring. This is the ECU checking the voltage of the lights for any bulb that might be out. LED lighting uses such low power it will flag as a faulty bulb. By using diagnostic equipment such as the GAP IID tool you can turn off the checking (hot and cold monitoring) of the bulbs to get rid of the error messages.
But remember to check the bulbs work visually on a regular basis as a back up as the computer will not do it any more. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #376671 10th Mar 2016 12:04pm
AKIS
Flashman many thanks for yr reply which noted
Post #376677 10th Mar 2016 12:53pm
jam220
United States 2007 Range Rover HSE 4.4 V8 Bonatti Grey
Unnecessary quote removed
Quick question or maybe not so much haha. I bought a crash 07 that im currently doing the facelift. Its seems some post have different parts list thats needed. So far I got the headlights, 2010 front bumper, two bumper brackets (lr011467-lr11577), Bumper bracket (lr011574), 2010+ grill F,L &R. My question is do i need a different headlight connector? or do need to do some splicing or repining if so please explain. Another question is the fenders: This post is the only one that i saw that mention modifying the fenders or changing them to 2010+ type. Can you confirm this? Thank you very much
Post #390800 8th Jun 2016 5:38pm
Danwilderspin
Guys do these look like the right sensors for the new front bumper seem cheap for 4 https://www.ebay.co.uk/itm/221867341063
Post #397352 23rd Jul 2016 9:38pm
jam220
There are some other sets on there with the trim for $80..i was going to use them but went with a diff option
Post #397372 24th Jul 2016 3:31am
Danwilderspin
What do you mean with the trim don't these just push into the new bumper? Do these look correct as seem very cheap for 4
Post #397395 24th Jul 2016 9:49am
Danwilderspin
Another question - is it possible to switch on the cornering lights as I have these?
Post #398156 28th Jul 2016 10:40pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I'd like to know if they are the correct parking sensors too as I have just bought 2010 front bumper as a start to my facelift. Also are they painted when fitted to the original bumper from factory? 2004 RR 4.4 V8 Autobiography
Post #398163 29th Jul 2016 12:01am
Danwilderspin
i think i am going to bite the bullet and see -
also how quickly could i realistally do this? if i had all tools to hand could i do it in a full day?
Post #398193 29th Jul 2016 9:19am
mattstevenson2005
If you already have the AFS cornering headlights and you buy the 2012 Corning headlights you can wire them up to work just follow the wiring diagram.
It is a 2 day job to remove old face, make modifications and fit the new one really. 2 1/2 days if your doing front and rear upgrade
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #398246 29th Jul 2016 1:26pm
Danwilderspin
If o have a 2002 how do I know if I have cornering lights?
Post #398582 31st Jul 2016 10:02pm
mattstevenson2005
You won't havecornering lights on a 2002 they weren't around until about 2007ish and they can't be retro fitted to earlier cars.
Matt Current
Post #398601 1st Aug 2016 12:12am
