Home > Technical (L322) > Final Stage Resistor
fogotter
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Hi Chaps,
looking for some advice. Got a 2003 td6 L322. The heater blower doesnt work. All the lights come on to the switch though. Also checked the maxi fuse 61 and its fine. Would the FSR be the right choice next to replace?
Just to add to it the rear blower works fine.
regards
Paul
Post #375538 3rd Mar 2016 1:56pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
rear heater is on a seperate FSR so it does sound like it could be the front FSR that is playing up
have you checked for a live at fuse 61
nige
Post #375556 3rd Mar 2016 3:33pm
fogotter
Hi Nige,
Not yet, the fuse looks fine though from here
Paul
Post #375557 3rd Mar 2016 3:43pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Paul. As long as you have power to the fuse it's probably your next cheapest option. They are a bit of a Censored to get at but once you train your arm to bend in three places they are not technically difficult and around £40 to buy. Did mine on my 2004 Td6 and it did the trick. Good luck. Thumbs Up
Post #375782 4th Mar 2016 9:30pm
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
had the same problem on my 2002 td6, turned out it was the brushes in the heater motor itself
Post #375883 5th Mar 2016 7:10pm
fogotter
Well,
Managed to swap out the FSR, they must have been put in by pixies with little hands because mine is now bleeding profusely. Still the blower now works a treat so job done.
Thanks to everyone for all the advice it was a great help.
regards
Paul
Post #376119 7th Mar 2016 12:03pm
diesel Dave
Very Happy love it when a plan comes together, nice one Paul. Mr. Green
Post #376227 7th Mar 2016 7:48pm
