Home > General (L405) > Question About Keyless Entry on MY15.5
Jkay
Australia
Quick question about Keyless Entry
Sometimes I need to press my finger on the door handle to unlock
Sometimes it just unlocks automatically when I walk up to the car before I even touch the door
Sometimes neither works. It won't unlock when I walk up to the car, and when I press my finger on the door handle it just keeps re-locking the car (no matter how many times I press my finger on the door handle). In this case I either use the fob or another time I just tried opening the door and it unlocked just as I pulled the handle
Surely this can't be normal?
How is it actually meant to work? Confused
Thank you
JKay 2015 SDV8 Autobiography - Black, Cirrus, 22" Style 707 Wheels
Post #375935 6th Mar 2016 7:59am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
You should only press your finger on the face of the handle to lock the door. Unlocking should happen when opening the door as normal. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #375937 6th Mar 2016 9:06am
I never use the button - just walk up to the car, with the key in my pocket and open the door.
You can tell there is a split second delay and it unlocks the car but opens in one fairly smooth flow.
It sounds like you have a fault to me - process of elimination - try the other key & try other doors
Post #375944 6th Mar 2016 9:38am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
The "dimple" is for locking.
The inside of the handle is for unlocking.
So, when approaching a locked car, just slide your hand into the gap (as you would to open the door if it weren't locked. As soon as you touch the inner surface (the back of the handle where your fingers would naturally grasp the handle) you should hear it unlock. Don't touch the dimple.
To lock, touch the dimple (but don't hold the handle) once to lock it. Twice to super lock it (you will hear an extra thunk and a beep). Don't hold the handle as then the car is not sure what you are trying to achieve (a lock signal from the dimple and an unlock from the inner side). The dimple is not as sensitive so you sometimes need to touch it a few times.
Does that make sense?
Post #375945 6th Mar 2016 9:42am
EdJ
I always "super lock" it, but never really sure what the difference is. Why would anyone not super lock it? Does it use more battery for example? 2024 Range Rover P550e AB
Post #375953 6th Mar 2016 10:31am
i always use the key fob - cause the key less go system is not very good. Mad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #375955 6th Mar 2016 10:43am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
I prefer the keyless...
As long as you're within a metre ( longer arms, and you may have problem Laughing ) of the car, as soon as you touch the inner surface of the handle, the locks almost instantaneously disengage and a simple touch of the dimple section locks them. Press that a second time and the super lock engages along with a Confirmation chirp.
Keeps the keys in your pockets out of halms way.
Great feature Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #375957 6th Mar 2016 10:57am
Jkay
Australia
Thanks for the replies. So the fact mine sometimes unlocks when I walk up to it before even touching anything might suggest I have a fault
Makes perfect sense Emperor Mong. It may have been explained to me by my dealer but I was probably too excited to retain any information at the time
I'll try the dimple to lock and just go to open the door to unlock tomorrow morning
I just finished washing the car (key in pocket) and it must have locked/unlocked more than 15 times in the hour I was there. Didn't even need to touch anything for this to keep happening. Was a little annoying having the mirrors fold in and out each time (especially when trying to wash and dry them)
I eventually used to the fob to unlock and this stopped 2015 SDV8 Autobiography - Black, Cirrus, 22" Style 707 Wheels
Post #375964 6th Mar 2016 12:22pm
Mine does that if I wash it with the key in my pocket
Post #375965 6th Mar 2016 12:32pm
paulmoran2
The conductivity of the wash water must effect the handle touch sensor.( BTW its all door handles that can be used for the feature) So I'd say it's best to leave the fob safe in the house whilst washing. As long as the fob is more than a metre away from the car, it should not unlock / lock Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #376005 6th Mar 2016 5:42pm
That's pretty standard my old Lexus and Merc did the same, used to unlock it then take the keys indoors before washing them... wish my FF had it, super feature... Thumbs Up Pete
Post #376012 6th Mar 2016 6:15pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
It's worth saying that I think LR changed the design to a 'dimple' rather than two horizontal lines somewhere around 14MY. I never thought the 13MY locking system was very good.
Post #376029 6th Mar 2016 7:56pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
The first lock doesn't set the internal sensors and is used if you have a dog in the car for instance. The double locking activates everything and means anyone inside and moving in the car would sound the alarm.
Post #376054 7th Mar 2016 12:21am
