Home > Technical (L322) > Sunglasses Holder Won't Close
dhallworth
On the SC the sunglasses holder is a nightmare to get to latch closed, it just keeps springing open again. If you change where you press it and apply a bit of pressure to each side, after much faffing around it will latch but it's getting bloody annoying.
Is there a fix available for these or do they just need to be replaced?
Have had a look on the search tab but can't find anything.
Post #376055 6th Mar 2016 11:29pm
2x 8mm headed bolts hidden (look inside with a torch to see them) undo and pull it out David, its then obvious how it works... Could just need a clean?
Post #376060 7th Mar 2016 12:16am
dhallworth
Thanks Craig, will give it a go tomorrow. With the sun being really low over the last couple of days it's driving me nuts!
Post #376062 7th Mar 2016 12:22am
Post #376063 7th Mar 2016 12:25am
dhallworth
Managed to get a look today and found a load of crap in the mechanism, cleaned it up and put some white grease on it, it's now all back to normal.
Thanks Craig!
Post #376453 8th Mar 2016 10:59pm
Thumbs Up Thumbs Up Thumbs Up
Post #376463 9th Mar 2016 12:28am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #376470 9th Mar 2016 5:45am
