![]() | Home > Technical (L322) > GEARBOX D'OH!!!!!!!!!!!!! |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
isn't towing 5.2 tonnes on the highway behind any car illegal? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Now a days it is, the old Land Rovers were plated to tow in that region, but with the entry in to the |
3.6 TDV8 towing 5.2te (inc' trailer). The FF did this many many times and the trip included a mile up a 1 in 8 plus several shorter but steeper climbs yet never had to come below 45 (B roads - not motorways - so no run up). No problems at all and compared to the D3 before it chalk & cheese (engine not chassis).
Arrr I see now, the 3.5 tons max weight is the trailer weight not the total Train Weight which is nearer 6.6 tons for a ffrr towing a trailer |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8671 ![]() ![]() ![]() |
Glad it's sorted mate, good job... |
I hope so Buddy..... cos if it's still playing silly b uggers it's a full rebuild |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hope they've sorted it for you miggit. |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Is that pick it up, test it, sell it? |
Sorry but have TDV8 :p Ed |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Valve bodies are serviceable items. In this country people only service via fluid and filter changes ( if that.) Valve bodies are serviceable.
Ok lets do some clarification..... when the gearbox was rebuilt in September 2014 the valve body was serviced, it had new seals and gaskets. But what it didn't have is the Sonnex replacement valves, where they enlarge the valve port and insert a new valve seat, because at the time it was very specialised work requiring expensive jigs, and only a handful of companies offered this service. 18 months on the Sonnex re-valved body is more widely available, as more gearboxes require the re-valve treatment and demand has risen and more companies have invested in the kit |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1005 ![]() ![]() |
Just out of interest I sometimes have to replace the main pressure control valve in 5HP24s with the oversized Sonnax valve if it gives a poor vacuum reading (indicating excessive leakage through wear).
Phil, from what I can gather you need a different jig for each valve block and I've been lead to believe that they ain't cheap either.... and this is the reason that some places will do the GM valve bodies and others the ZF.... but I'll assume that because there are more peep's offering this service either the price of the kit has come down or the demand has risen.... All I know is in 2014 when you searched Sonnex nearly all the pages that popped up were from the States.... this year there are a few in the UK |
