![]() | Home > Off Topic - Other Cars > Freelander problem |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Hi guys
I dont think the Pressure sensor is that much money compared to a recon pump and worth a shot as i think they are £40+
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1848 ![]() ![]() |
There is a known issue with the rail pressure sensor wiring, and a repair loom |
Thanks guys
It's a known issue of poor pin tension inside the connector, causing an open circuit issue, regardless of continuity back to the ECU |
Ah, thought is was just broken cables and corrosion in connectors. AA man did give the connectors a good wiggle while I cranked the engine and readings didn't change 56 TDV8 Vogue SE
The overlay harness is less than £40
Not tried it with easy start yet. I will get some at the weekend and give it a shot 56 TDV8 Vogue SE
eventually got this fixed. despite all my testing showing it was not the wiring to the HP sensor Mikey was correct |
