![]() | Home > In Car Electronics (L322) > bluetooth to android connection on a RR 2005 vogue |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Hi and welcome, on your phone search bluetooth devices and then select landcover and enter 2121 as the pin, thats if you have the touch screen model. |
tnysctt Member Since: 10 Mar 2016 Location: durham Posts: 47 ![]() ![]() ![]() |
yep its the touch screen model just dosnt seem to find any connection but i will try again cheers |
you should see landcover come up on your phone and pair with 2121, if you have the old module you will have to pair every time you get in the car. |
cheers will let u know the outcome |
nope still wina pair wont even find the landrover signal as though no signal being sent out |
It will be sending out a Bluetooth signal because if it was gubbed the whole infotainment system would be down , the problem is probably that your phone is too new for the ancient nokia phone unit . It might even be too old to update the firmware though so you will need to look for a newer nokia unit or replace with a unit from a D4 but that is not plug and play but not that hard either .
kettles on cheers |
Not true, could have been easily and cheaply bypassed if it got wet... We need a pic of the inside of the passenger side boot once the first panel is removed to help show what unit you need to check FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
