![]() | Home > Maintenance & Mods (L322) > Loud noise coming from under the bonnet, left hand side |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
FBH? Cheers
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Sounds like your FBH kicked in there Bud, they stuff them deep in the wheel arch area behind the glovebox, and they draw their breath through the gill on the passenger side...... mine has developed a whistle when its going, did make me jump when it first kicked in |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Don't you have to activate the FBH though, like time it to come on, on a frosty morning. I mean the engine had warmed up. It did frighten the life out of everybody in and around the car though |
They come on by them selves when it's cold to speed up the warm up of the engine / heating system... I didn't think that mine was working, and then it got cold and I couldn't stop it from whistling |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Mine sounds like a jet turbine, started smoking as well.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Fbh smokes on my disco, it's pretty common. |
NMJ. cheers. I suppose if it ain't broke, don't mess with it.
they come in at 6deg or below on startup to raise temp to 40deg and then maintain it at 40deg which is why the make alot of noise initially and then it subdues once 40deg has been reached. Cheers
Mine doesn't smoke , it burns loverly clean petrol |
i didnt think the SC had them, something new learnt. can you remote heat yours too? Cheers
Yes , works just like on a desiesel I have a T91 remote and it comes on automatically a 6ºC and under to help speed up heating . It's very unusual to have one specced on a Supercharger but there are one or two around and my car was one of JLR own and has absolutely every option fitted |
