|  | Home > Technical (L322) > Is the Heater system very very clever?? |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    |
 I understand that our cars are very complex, and something as innocuous as a heater system has algorithms and electrickery behind its operation.
|  10th Mar 2016 3:21pm |
| Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300      | Mine has a tip top battery but doesn't heat for at least 2-3 miles. I had always thought it was to do with the system not wanting to blow cold air in to the cabin. i.e. it waits until its really well warmed up before allowing the blowers to operate. Even though the petrol engine warms up quite quickly the heater seems to take much longer. 2012 5.0L S/C
|  10th Mar 2016 6:18pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Yes the car wants to charge the battery first Adam... Clever old things "aint um”   | ||
|  10th Mar 2016 10:48pm |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | Ta Craig and others   | ||
|  11th Mar 2016 8:36am |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020      | I think the ECU has some kind of priority where it distributes its power until the battery is at certain voltage.  I've noticed things like the heated rear screen will not come on, whereas the front screen will.
|  11th Mar 2016 9:21am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Yes Wealy, its all to do with the conversion to AGM batteries sir...  | ||
|  11th Mar 2016 9:48am |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Adam... Craig is talking a pack of lies, your FF is seriously broken and will never be the same again, I will do you a big favour and buy it off you for £5000.....  | ||
|  11th Mar 2016 5:32pm |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | Add a zero and it's yours! Discovery 4 HSE
|  11th Mar 2016 6:04pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | £05000........  | ||
|  11th Mar 2016 6:39pm |
|  11th Mar 2016 6:53pm |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613      |
 I thought it was mainly to do with reducing emissions. Basically the batteries are nice large reservoirs of power so can survive a few minutes without being recharged. It gives the engine time to warm up, the moment the car detects you braking it loads up the alternator more so that rather than waste power in heating the brake discs you recover some of that. Simple regenerative braking   Similarly when you accelerate hard it can remove load from the engine allowing more energy to be used accelerating the car up to speed and thus make it more efficient. Years ago when these started coming out BMW and Volvo reckoned they could get ~3% increase in fuel economy simply by doing these tricks. The research and projects I did at the time showed that this was perfectly realisable. Ed | ||
|  11th Mar 2016 6:55pm |
| Posting Rules
