Home > In Car Electronics (L322) > Radio and DAB interference when using rear heated screen!
Zeppfish
Guys... I have noticed a bit of a strange one on my FF.. When you put the heated rear screen on while the radio is on you get some serious interference the moment the button is pushed until you turn the heated screen off!! It almost seems like there should be some kind of line suppressor fitted to the screen elements. I understand that the heater elements are also the radio ariel as well.. any suggestions? Its driving me nuts Evil or Very Mad 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #377072 12th Mar 2016 4:31pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I had this on my L322. The dog had scratched at the glass and damaged the heating elements. I had to have a new rear screen ( but I persuaded my insurers it was damage to glass and therefore claimable under the glass element of my policy!)
Post #377075 12th Mar 2016 4:53pm
Zeppfish
Mmm thought that might be the case, checked all the antenna module wires and connections and all looked good, clean, and dry, I noticed one line in the rear screen was not defrosting, is this enough to do it?... 2006 RR sport HSE
Post #377093 12th Mar 2016 8:50pm
supershuttle
I have exactly the same problem, one bit not defrosting and I think it can cause the interference, I have to use DAB then switch to Radio after switching off the screen. I was going to try some electrical paint - when I get round to it Laughing Geoff
Post #377096 12th Mar 2016 9:38pm
Zeppfish
I was thinking about the electrical paint option, but the car is still under warranty from the garage I bought it from! Think I might chance my arm and see if they will replace the glass under warranty 2006 RR sport HSE
Post #377141 13th Mar 2016 5:20am
