Home > General > How reliable has your FFRR been?
Andy
Just reading through all the reviews on What Car? Hardly anyone is happy with their RR.
http://www.whatcar.com/car-review-readers.aspx?RT=2245
In the short time I've had mine, I've got no complaints. Early days I know. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3771 13th Mar 2009 1:16pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
People like to winge its British Rolling with laughter
Post #3772 13th Mar 2009 1:17pm
Andy
True, but when you're spending £60k + on a car, it has to be right 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3773 13th Mar 2009 1:21pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Does it????
Ask an owner of an Aston, Maserati or Merc to name a few and very few are Shocked
Post #3774 13th Mar 2009 1:24pm
Andy
Ok, I'll re-phrase that. If I spent £60k in a car, I'D want it to be right!! Wink 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3781 13th Mar 2009 1:46pm
All brands have their niggles.
Mine?
Diff Oil leak twice, after driveshaft replacement (dealer's fault)
Parking sensors went wappy for a while (gone away now)
Rear washer not spraying enough water Discovery 4 HSE
1993 90 Tdi
Post #3785 13th Mar 2009 2:07pm
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
It Part of the Joy of ownership..... 4.4 V8 Vogue Adriatic - Cream leather
Post #3790 13th Mar 2009 3:01pm
Vogue
no problems yet - apart from a dodgy battery replaced under warranty. My seat base has split though - plastic thingy where the elec buttons are mounted - I believe this is a common problem???
Post #3792 13th Mar 2009 4:14pm
Pazuzu
Mine has gone as well, a dealer quoted £70 for this trim.
Cheers,
Phil
Post #3793 13th Mar 2009 4:27pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Reading through, most of the moans tend to be concerned with the TD6 and pre 06MY.
Take them out of the equation and it would have been virtually 5* all the way. Mr. Green
Been in a LR product for almost 14 years now so I know what to expect and I expect to know what's going on. A lot of the time the moans are to do with poor dealer fixes which are not the intrinsic fault of the car. Also, it's true to say that there are folks out there who just like to moan.......... Rolling Eyes The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #3794 13th Mar 2009 4:29pm
Aeroresh
2014 Range Rover Vogue SDV8 Nara Bronze
Its got to be said, reliability for such an expensive car is pretty poor.
I get the impression they're just poorly made.
eg I remember fitting rear lamp guards to a previous L322 I had. On removing the rear lamps, one side had one washer and a pin holding the lamp, and the other side had 3 washers and a bit of plastic holding it in. This was a brand new car at the time meaning it was done at the factory!
The one Ive got at the moment has a squeeky drive belt when cold, the driver's window has come away from its runners and there's a little drip of oil taht appears under the car if left for a day or two!
I tend to save all the faults up for service time, otherwise it would just live at the dealer....This has been the same on the last 3 examples Ive had so I reckon its pretty typical of the mark...That said, still luv 'em tho!
Rolling Eyes '14.5 SDV8 Nara Bronze for sale
'17 BMW 740e Msport Individual on order
'17 Jeep Grand Cherokee SRT 6.4 Hemi on order
'16 Bentley Continental GT V8S Mulliner Driving Spec
'07 Alfa 159 3.2 Q4
'05 Mini Cooper R50
'95 Volvo 850R modified to 400hp
'89 Jaguar TWR ed XJ-S V12 Convertible
Post #3798 13th Mar 2009 9:15pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
i tend to disagree in the fact that yes you shoild expect a fault NO matter how much you spend , also i think the range rover is a very good vehicle in terms of quality , fit and reliability i know im gonna get slated for my comments but i feel that a lot of the problems , not all of them tho are caused by general lack of use i.e
1) how often do you use low range / with manual shift - most probly never get used
2) suspension faults - how often does your suspension go thru its full travel , how often do you use off road height / kerb height - most probly very little
3) HDC - probly never
4) air con - only in summer i suspect
and so on
all these components have vast arrays of electrical component / sensors if you dont use them they play up and you get your fault codes error messages and because 99% of owners only buy a RR is for looks and are not interested in what it can do , these are the people who moan when they have problems and then slate the car for being at fault when really the fault is the owner my rant just my observational oppinion Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #3817 14th Mar 2009 1:59pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
This is the first that has not gone back to the stealer on the back of a lorry, so far. It would help if the dealer had a faint idea of how it should work. letters not necessarily in the right order
Post #4868 10th Apr 2009 7:34pm
dan_uk_1984
1) how often do you use low range / with manual shift - most probly never get used.
Lots when it snows.
I actually use Access Mode twice a day, just because I can, I also use extended whilst sat in traffic and watch the sheer amaizement on the face of the driver behind me!
Loads when it snows - now I just use it in the multi storey car park, mainly for my own amusement!
Is on all the time becasue I appreciate that it dehumidifies in winter.
I think that a lot of problems are down to shoddy workmanship/build quality, I suspect they are put together by people who just dont give a damn (but that may be an unfair assumption)
I also think a lot of problems are down to poor maintenance - not nesaserily by the owner, but by the poorly trained dealer staff. (When I went to get my diff fixed they broke my steering column by holding it on adjust till the motor fked up!)
Post #4869 10th Apr 2009 7:46pm
speedymarktd6
hi dan even tho you use some of the functions for eigher other peoples amusement or the look of wander on there faces when you do the things you mention at least these sytems are being used so in theory you shouldnt have a problem Thumbs Up onto no6 Range Rover
Post #4871 10th Apr 2009 8:28pm
