Home > Technical (L322) > Steering reach not working
Madmutt0
Hi I've just noticed my steering wheel doesn't auto adjust when I get in my Ffrr
If I adjust it with the lever I've got up and down movement but when I adjust the reach I just hear the motor
I believe the nylon bracket can snap if so is this a hard job to do can I get to it in the footwell
Thanks for any info
Post #377304 13th Mar 2016 10:48pm
http://www.fullfatrr.com/forum/topic34124.html
Or try searching Thumbs Up
Post #377308 13th Mar 2016 11:32pm
Madmutt0
Plastic bracket
Hi think the plastic bracket has broken can this be replaced without too much trouble thanks
Post #377333 14th Mar 2016 11:06am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
You need to get in touch with Uli, member on here , username meerbush, he sells the fix on eBay + a full write up on here somewhere
Post #377343 14th Mar 2016 12:31pm
See the link I posted above Whistle
Post #377366 14th Mar 2016 2:40pm
Clivefog
It works very well.
Don't look like much for the money but fixed it and not that difficult to do.
Step by step instructions from Uli included, plus email link if you get stuck/need clarification.
Post #377373 14th Mar 2016 3:28pm
Madmutt0
Thanks
Thanks will look at the week end to see if it is the bracket or the little block my steering wheel has no play at all if I try to move it by hand
Post #377376 14th Mar 2016 3:51pm
Madmutt0
Broken brackett
Hi can anyone give me some advice please I've took off the steering cover and yes part of the bracket fell out
The question I have is if I buy the bracket can I replace without too much trouble or if I cable tie where do I place the ties thanks bob
Post #377513 15th Mar 2016 12:34pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
You can replace the bracket fairly easily, have you found the small narrow drive shaft?- if its it not there its usually fallen down the back of the footwell either in the lower dash tray or mine was sitting on top of the trim behind the pedals. It will be there somewhere!
The bracket itself is pretty tough to locate fully - it needs a fair bit of force to pop it into place - I struggled and swore for about an hour before placing a large spark plug socket over the top of the raised nobly bit and then hitting that with a rubber mallet popped it into place. The bracket is available for about £30 (ridiculous price) and the part number is QYH500030
Hope that helps
Nick Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #377533 15th Mar 2016 1:50pm
Madmutt0
Thanks
Hi nick yes little flex was still in place is it easy to fit back together I'll let you know how I get on thanks again bob
Post #377537 15th Mar 2016 2:11pm
Madmutt0
Cable
Hi nick how should I put the cable back is the a order thanks bob
Post #377549 15th Mar 2016 2:53pm
nicksaab
Hi Bob
The spindle locates into a drive hole in the tilt mechanism at the bottom of the column, then I think the other end fits into the motor and the bracket then holds the motor to the column. Its been a while since I did it, but seem to remember it was fairly intuitive once I got in there. There are a couple of pictures on the forum somewhere which shows how it all fits together.
Hope that helps
Thanks
Post #377554 15th Mar 2016 3:25pm
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I'd suppose that it would make sense for those of us that did not yet have any issues with the mechanism to go to the bother of removing the bottom steering cover and greasing anything that moves. Smile
Post #377575 15th Mar 2016 5:28pm
Declan303
Well that didn't take long. I decided to go do it instead of talking about it. Very Happy All greased up now, 15 minutes work.
Post #377576 15th Mar 2016 5:28pm
Madmutt0
New bracket
Ordered new bracket and cheapest I could get was main dealer at 32 pounds even cheaper than parts dealers
Post #377711 16th Mar 2016 10:18am
