Home > Maintenance & Mods (L322) > Damaged drivers door seal...
I expect a few of you with old crates like mine will be familiar with this sight...
Well a new seal is around the �65 mark.... If you look on eBay it appears that they are handed and there are very few drivers side ones as they all end up looking like the above...
They are in fact the same seal for both front doors so buy a passenger side one, they are always in better condition as they get used a lot less, and it fits just fine...
I paid �15 delivered for mine so a fifty quid saving.... Thumbs Up Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
-Click here for Thread-
Post #377258 13th Mar 2016 7:38pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Thanks very much for the info pete, good bloke you are, passing on money saving information.
Cheers Greg. Thumbs Up
Post #377263 13th Mar 2016 8:06pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Can do some wading now then pete Rolling with laughter (was the front wheel ok ? after the ford)
Post #377265 13th Mar 2016 8:08pm
Yep, no marks at all on it, shows how strong the wheels and tyres are....
For those wondering, we hit a rock in a ford up on the North York Moors, it was massive, probably over a foot high, the front nearside wheel hit it straight on, it was made of sandstone, it deformed the tyre off the rim enough to fill about 8" of the bead area with lumps of rock... It wasn't leaking at the time so we just carried on, the stones and bits worked their own way out and it was fine....
Had it popped off the rim and checked it and no damage at all to the tyre carcase or the wheel.... Pete
Post #377269 13th Mar 2016 8:19pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Hay lands, do those seals just pop in or is a sealant required ?
Post #377318 14th Mar 2016 1:25am
No sealant on them, they just grip the edge of the opening.... Pete
Post #377320 14th Mar 2016 3:01am
should have used more gummi pflege rubber treatment on that seal Pete Laughing ... - .- -.
Post #377337 14th Mar 2016 11:19am
J evro
Cheers Thumbs Up
Post #377339 14th Mar 2016 11:38am
Stan... not caused by freezing... happens on all the cars I've had, being 6'5" means I have the seat all the way back, getting in and out means you rub against the seal every time, it only gets damaged in that particular place... Never happens in all the two doors I've had where the door opening is larger.... Thumbs Up Pete
Post #377355 14th Mar 2016 1:50pm
i was only jesting , but now i know tall you you are , i can call you Pete the Giant!... Laughing ... - .- -.
Post #377358 14th Mar 2016 2:19pm
Rolling with laughter Rolling with laughter Pete
Post #377361 14th Mar 2016 2:30pm
