Home > Technical (L322) > 2012 adaptive headlights
Berty
England 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Are my 2012 autobiography headlights bi xenon, ? And does that mean full beam is xenon ? Just getting confused reading threads about upgrading them, also the side light LED,s in the circle can they be changed ? And which fog light bulbs would get rid of that yellow look ? Thanks berty
Post #377392 14th Mar 2016 8:01pm
Lost for Words
Yep, bi-xenon meaning a dual beam xenon projector, but there are also additional halogen main beams. Thumbs Up
For "whiter" bulbs (fog and main beam infill), take a look here: http://www.disco3.co.uk/forum/topic142054.html Be quick if you want some, because I'm looking to put the first order through tomorrow if possible. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #377395 14th Mar 2016 8:43pm
Berty
So what would I need to improve my full beam, and make my fogs whiter?? And how involved is the fitting, will it cause any issues, I've heard a few aftermarket bulbs cause warning light to come on, also can I change the side light bulbs I like this look, thanks berty
Post #377412 14th Mar 2016 9:36pm
LEDs for fogs. Whiter than a white thing :-
 Got - 2017 SDV8 Autobiography in Loire Blue
Post #377417 14th Mar 2016 9:48pm
Berty
Where did you buy them m8 ? thanks berty
Post #377419 14th Mar 2016 9:55pm
Lost for Words
Sidelights are built in so not changeable. You'd need a pair of H7s for the main beam and H11s for the fogs (the Xtreme Whites would be what you're after). As high quality bulbs drawing standard wattage, they shouldn't cause any issues (fully legal also). Others will be able to advise better as regards fitting (I'm not a FF owner).
LEDs as above wouldn't give a fog beam, though there are those available that do, at a cost.
Post #377421 14th Mar 2016 10:03pm
Berty
Right on investigation of my yellow main beam headlights it would seem there a halogen build so how is that a bi xenon headlight ? I always thought bi xenon meant xenon full and dipped, is this another money making spec change by Landrover or has my car had a bump at some point :unsure:
Post #377595 15th Mar 2016 7:50pm
Lost for Words
See my PM - if they're adaptive, they are xenon, but they still have an additional halogen bulb. Thumbs Up Visiting from DISCO3.CO.UK
Post #377615 15th Mar 2016 9:10pm
