![]() | Home > In Car Electronics (L322) > L322 Carphone options |
| 24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166
Hi
| navrac Member Since: 29 Feb 2016 Location: Suffolk Posts: 10
Are you sure it hasn't already got the bluetooth module installed as part of the nokia kit? Mine gives no hint that it has bluetooth until you get in the car scan on your phone and LAND ROVER pops up. |
| tnysctt Member Since: 10 Mar 2016 Location: durham Posts: 47
i am trying the same all the correct module etc r there but still no landrover signal when i search via bluetooth |
Hi
| Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223
When i searched fo rmy bluetooth i got a hexadecimal string nothing indicating that it was the landrover L322 2008 vogue
Ahh mine is a bit later so it had the bluetooth module in the nokia box as standard. I did have to upgrade it though to get it to work properly and give me the phonebook etc. However mine was a 2005 MOST system which is completely different.
IVor - mine came up with a hex screen as well the first time. I paired with it using the code 2121 and since then it announces itself as land rover. Give it a try! |
Unnecessary quote removed
The one you pointed out on ebay wasn't on the list of generation 3 and up ( the original post said don't bother with generation 1 or 2 modules) so the ebay link I posted was 84 21 6 934 961 on the close up of the label so was the top one on the list - 3rd generation.
| Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232
http://www.bluetoothexchange.co.uk/
bluetooth exchange are for the MOST touchscreen ones like mine - they are 2005 upwards. They upgraded mine - very quick service. |
That would be great, except that service is only for the later models (04 onwards), not the pre-non-touchscreen stuff. |
| All times are GMT |
