![]() | Home > Technical (L322) > no radio! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
first thing i would do is dis-connect the battery for a while, this sometimes helps...have you done a search here for an answer..
Have you checked for moisture in the ICE compartment? Next step is to unplug the big multiplugs from the various components in the boot and give a liberal squirt of Electrical Contact Cleaner. I personally wouldnt use WD40 on these components, but have heard others have. In the future, always run the car with the AC on to dry out the interior air. ![]() |
Happened to me on a stock S-Type "R" 4.2 Supercharged Jag and all it needed was to be turned off an on again. I suggest you disconnect the battery and reconnect.
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 ![]() ![]() ![]() |
thanks for the replies- i will have a play around in the boot tonight and report back my findings. |
had a good play with the radio over the weekend/last night. found the fault to lie with the bm54 unit, removed the unit and tried a replacement out of a firends car and the system worked perfectly!
