Home > Technical (L322) > Air suspension playing up
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
The last few nights when I get home from work,I normally put my beast into access mode,but it doesnt want to do it.The light flickers but nothing happens. When i get into it in the morning and press down on the main switch it will go down.
Today I tried to out it down when I got to work(main switch) it still would not go down.
At the moment my iid tool is playing up so I dont know if compressor is on its way out or not.
Any suggestions greatly appreciated.
cheers
Post #377684 16th Mar 2016 5:22am
miggit
Unlikely to be the compressor if you can't get it to go down... recon I'd be looking towards the valve blocks / wiring faults..... Most of us have the opposite problem and the car refuses to go up Shocked and they don't do Viagra for Range Rovers Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #377741 16th Mar 2016 1:49pm
littlecub
Thanks Miggit,
I raised it coming down my street tonight and it went up.
Put it back to normal height then tried for low....no go.
So it will go up, but not down to low.
Anyone got any suggestions?
Post #377745 16th Mar 2016 2:41pm
try the vent valve on the compressor, might be blocked up....
kinda similar fault here,
http://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #377747 16th Mar 2016 2:44pm
littlecub
Thanks for the other topic Stan.
When I got home tonight I put it into access height and it did it.
So I don't know whether its that little bit of exhaust filter thingy is clogged or not.
I'll have to check when I get some days off next week.
cheers
Post #377964 17th Mar 2016 12:02pm
littlecub
Tonight I put it into high mode whilst coming up to my front gate and only the front went up. Censored
Access height don't work either now.
Couldn't hear anything from the compressor.
If I have to get a new compressor, how much are they, or is refurbishing the existing one the better option.
Thanks
Post #378157 18th Mar 2016 1:37pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Refurbed mine with the bagpiping andy's kit. Works like a dream now.
Don't know if they are available down under but, if you do get hold of one, the you tube walk through is brilliant. Should only take about an hour at most.
I know you don't get much rain down under, hae you checked in the spare wheel area for water.
just a thought.
Greg. Thumbs Up
Post #378158 18th Mar 2016 1:57pm
