![]() | Home > In Car Electronics (L322) > Satnav lost the plot |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
have a look behind the speaker panel and see if there are any lose cables or plugs detached, other wise try a battery disconnection.. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
There is something about this somewhere, something to do with the gps antenna in the shark fin as far as I can recall there can be water ingress and it can fail. |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
I had the same with mine I changed the sharks fin and all is jolly again |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
well in the true range rover manner it's fixed itself and giving me more info than before it now tell me about roadworks ahead L322 2008 vogue
NMJ might be correct in his assumption, its dry and sunny now so your nav is working ok, i bet the next time it rains you'll have problems... ... - .- -.
Yeah i know what your saying that was my first thought as well L322 2008 vogue
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Ditto. Mine was cracked. When the sun shone it worked. When it rained it didn't. Easy enough to fix and takes about 30-40 minutes. |
