![]() | Home > Technical (L322) > TDV8 intake manifold tuning valve location |
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
Hi,
the only pic I can find is in the Workshop Manual
After a lot of investigation I have found the location. It sits on the underside of the intake manifold between the throttle bodies.
| Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227
Hi
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2774
Isn't that just a vacuum chamber? The fault code description refers to an electrical short to ground in the control circuit. |
The WSM gave a picture of what is circled as the valve, but after a lot of investigation the IMTV is actually the electrics of the EGR.
