![]() | Home > Technical (L322) > Unidentifiable connectors in the engine compartment. |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
I have a few spares on my M62 2004, do you have secondary air injection unit (SAI)
| Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125
Yep top end connectors all seem to be in the right places.
Hi thanks for taking the trouble to come back to me on this.
The SAI kit is under the air filter box as you say and you have pipes running along the front of the engine i believe, i am sure it's only or emissions for when the car is first started to pump in more air while its on 'choke'.
Have a look at saints 'how to' over on the other side.
Well that would explain it!!!!!
Nope, i think i'm on my third MOT and as you say emissions are perfect, think it's just for when it's first started to tick some box somewhere no doubt |
Think I may have a much bigger problem now.
Don't panic, i have been there a few times, engine noise or transmission ? |
Worked out and sorted the gearbox just after I bought it. A flush and a new position switch sorted that.
Well it sounds to me like you are fully infected with the range rover disease and unfortunately there is no cure so i am afraid you are in the for the duration.
Valley pan looked as though it had been weeping but difficult to assess because of oil and dirt build up.
Malt sounds good, more of a guinness man myself, if i have learned one thing about the car, its good diagnostics.
Insomnia worrying about the bloody car. Eddie the eagle watch out 👀 |
| All times are GMT |
