![]() | Home > Technical (L322) > Unidentifiable connectors in the engine compartment. |
boatsandy1966 Member Since: 05 Dec 2015 Location: nr pagelsham essex Posts: 162 ![]() ![]() ![]() |
hope you get sorted and it isn't to costly 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Have you compared your noises, to any posts on YouTube, with their own m62 engine noise. It's true that the vanos 'cogs' can be noisy, I did mine, and now silent. But you need to know what your noise is, and when it happens, and maybe things like different oil, ie, changed, ( thicker oil) and possible exhaust cracked, etc. Is the car now holding water, and driving ok. . |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
The noise from the engine is only occurring when engine is put under load as in accelerating. I cannot think of a way to replicate it when the car is stationary. I thought about a rolling road but that would need to be a all four wheel setup I would have thought. I don't know of one in our area. I have tried putting the Park break on and chocking the wheels but that isn't working. I have jacked a packed the cars wheels off the ground and started the car and put it in gear and applied breaks. This is not good practice choose however carefully you support the car. I would not recommend this, the RR suspension has a huge travel on it.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8727 ![]() ![]() ![]() |
Pete...
Old scrapper?!!!
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I seemed to have stopped getting notifications of replies.
Hi thanks for that link to the article. That was the one I had read about the collapsed cat syndrome. But I couldn't find it again anywhere. I was probably looking in the "JAG section!"
Definitely no need to apologise, i have been there with the assignments and the continual battle with the FF.
