Home > In Car Electronics (L322) > [SOLVED] ULF Bluetooth IN - Nokia (6210) Car Kit OUT
Found my problem!
The 54 pin connector slides apart to reveal all the pin numbers, I had slide it back on the wrong way!
Using the pinout chart (not the colour one) as my guide reset all pins, inserted, fired up Navcoder on my Reisler USB interface and paired up with my phone just like that Very Happy
Now to test the phone controls and microphone Bow down .
Post #378340 19th Mar 2016 4:08pm
mjdronfield
Turnip !
Sounds like something I'd have done !
Hopefully sorted now.
Should have voice control enabled still.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #378342 19th Mar 2016 4:15pm
Hmmm, don't seem to be getting anywhere in terms of making or receiving calls.
I have unplugged the old Nokia kit up front, but left all the loom in the rear connected (inc the Connect 2 box)
Phone paired immediately I started the engine, asked for access to contacts.
Got a green light on the three LEDs for a little while.
Don't see the "white" Telephone screen? (although letters are white?)
Process for getting it up and running? .
Post #378463 20th Mar 2016 12:09pm
Not to worry, figured it out. Disconnected Connect 2 box and was able to make and receive calls, mic works OK, and mutes sound. Buttons on steering wheel work, need to do some reading up on how the telephone thing all works, and also need to tidy up my contacts!
Here is the Connect 2 box disconnected
And the two white connectors which are connected to the "Connect 2" loom. I am wondering if I can plug these two together and get rid of the Connect 2 loom ?
I also attach an updated pdf of pin assignments and cable colours, along with what I have gleaned on what each cable does. There are two tables one sorted by the original loom numbers, the other sorted by the new loom numbers.
http://www.fullfatrr.com/gallery/albums/us...0Chart.pdf .
Post #378483 20th Mar 2016 1:30pm
