Home > Technical (L322) > Think i'm missing a pipe
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hey Guys
Did the first real work on the L322 since purchasing today,c hanged the spark plugs thats a job and a half.
Anyway I think I'm missing a pipe, on the left hand bank looking at the engine on the supercharger theres this big pipe on mine its not connected to anything should it be is the question.
See red circle on the picture below.
Post #378578 20th Mar 2016 10:34pm
lighthouse
Better photo of the actual connector anyone got any ideas should it be connected to something or not, it looks too clean to never had been connected.
Post #378621 21st Mar 2016 9:58am
Don't know what it is but a google search finds this pipework....
Get Dan to check what it needs... Pete
Post #378649 21st Mar 2016 12:14pm
lighthouse
I saw that one which is a water connection onto the water system for the supercharger but not sure if thats a different model as the top looks different to mine and if it was water surely there would be a big mess in there.
Post #378654 21st Mar 2016 12:56pm
Best stick a request up in the Duckworths section and ask Dan to identify what should be connected...
Maybe it's used in the Jag but not the FF, you'd think they would blank it off if not used but stranger things have happened...??
Same setup by the looks of it, your's has cooling fins on the plenum... probably an update at some point... Thumbs Up Thumbs Up Pete
Post #378658 21st Mar 2016 1:10pm
lighthouse
Good idea, i guess it could be.
Post #378660 21st Mar 2016 1:17pm
Looks like your pipes are correct for the FF... Had a quick look through the workshop manual, can't find what that is but it's not plumbed in with the SC cooling...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #378663 21st Mar 2016 1:27pm
lighthouse
Thanks, looks like you found what i did, but the connector looks clearer than the bits around it that was my concern,
Post #378665 21st Mar 2016 1:36pm
Can just see it on this one... nothing on it... and it's in an FF
Forget it then... Thumbs Up Thumbs Up Pete
Post #378666 21st Mar 2016 1:38pm
lighthouse
Thanks for all the help, put my mind at rest now.
Post #378668 21st Mar 2016 1:41pm
