Home > Technical (L322) > Rear bushes?
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Rear bushes?
Are there any bushes etc that are notorious for wearing on the rear of the car?, the reason I ask is i have a new set of tyres to fit at the weekend and have noticed that on the N/S rear the tyre wear on the inside 2" is much more than across the rest of the tyre, when i took my 22" wheels off this was the case as with the tyres iv'e been running since i bought a set of 19" with half worn tyres.
In each case the car has been 4 wheel aligned on the hunter machine at my local tyre place, so I am thinking must be something bush wise? Any ideas?
Post #378633 21st Mar 2016 10:20am
this will help,
http://www.fullfatrr.com/forum/topic32920....per+bushes ... - .- -.
Post #378635 21st Mar 2016 10:26am
Jimmy C
Thanks for the link , have had a read and i guess its the rear track control arms i need ?
Post #378637 21st Mar 2016 10:33am
The only arms on the rear are the toe control arms, I think you will find they are OK, it is usually the upper and lower hub bushes as in Stan's link... Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #378648 21st Mar 2016 11:10am
Jimmy C
Ordered upper and lower bushes and arms for both sides, so hopefully that should cover it, thanks for the help all.
Post #378671 21st Mar 2016 1:19pm
Are you fitting them yourself...?? Pete
Post #378705 21st Mar 2016 5:11pm
Jimmy C
No my local indy is fitting it all, then fitting my new tyres and then doing the 4 wheel alignment/tracking
Charging £330 inc vat which is reasonable I think ( I'm supplying parts).
Post #378712 21st Mar 2016 5:45pm
I'd order new bolts, washers and nuts for the rear hub bushes, the old ones will be very rusty and very tight, I snapped one of mine getting them out, they have a cam washer arrangement for camber adjustment so you can't just use any old bolt, got mine from Dan at Duckworths, not that much money... Thumbs Up Thumbs Up Pete
Post #378726 21st Mar 2016 6:35pm
Jimmy C
Thanks for the advice I will pm Dan now and get them ordered
Post #378755 21st Mar 2016 8:02pm
