Home > Technical (L322) > New timing chain?
somchie
Sweden
New timing chain?
Does anyone know how many hours it takes to change the timing chain in a 5.0 S/C?
My FFRR is a 2010 MY, and I understand there is an upgraded version of the timing chain? Range Rover SV Autobiography LWB 5.0 S/C -17
Aston Martin Rapide S -17
Range Rover Sport SDV6 Autobiography Dynamic -14
previous: Range Rover 5.0 Supercharged -10, Land Rover Defender 110 SW LXV -14, Discovery 4 HSE -11
Post #378869 22nd Mar 2016 2:23pm
Fretless
Scotland 2011 Range Rover Vogue TDV8 Baltic Blue
I remember someone recently saying 15 hours Shocked but don't quote me.
Good luck Thumbs Up The best 4.4 x far
Post #379012 23rd Mar 2016 11:25am
its a huge job that will take about a week ...pretty sure there's a tsb on the rattling timing chain.. ... - .- -.
Post #379037 23rd Mar 2016 3:50pm
wealy
Why do you need to change the timing chain - they are pretty much bullet proof?
Post #379040 23rd Mar 2016 4:30pm
dhallworth
On the 5.0 there was a TSB as Stan says.
If the owner reports a rattling from the front of the engine then LR will change the chain. It's a massive job and I'm not sure it's one I'd trust any of our local dealers with tbh.
I think it's more to do with the tensioner rather then the chain but I might be wrong.
Post #379043 23rd Mar 2016 5:00pm
wealy
There was a problem with the old 4.2 plastic tensioners, but it was rectified with aluminium ones. I know - I'e stripped one. But I'm sure its well sorted and I don't know of a problem with the 5.0?
I'm interested if there is a TSB?
Post #379052 23rd Mar 2016 5:43pm
duckworthparts
Site Sponsor
SECTION: 303-01
5.0L AJ133 Primary Chain System Engine Noise
AFFECTED VEHICLE RANGE:
Range Rover Sport (LS) Model Year: 2010-2012
VIN: 215623-759577
Engine: V8 5.0L Petrol
V8 S/C 5.0L Petrol
Range Rover (LM) Model Year: 2010-2012
VIN: 306630-393639
V8 S/C 5.0L Petrol
Discovery 4 / LR4 (LA) Model Year: 2010-2012
VIN: 513326-652214
MARKETS:
All
CONDITION SUMMARY:
Situation: A customer may report a concern of a rattle/clicking noise from the front of the engine which maybe more prominent when the engine is at idle speed. This version has been issued for a change to the Warranty Table.
Cause: Wear on the timing chain lever which results in reduced tension on the timing chain. Suggested Customer Concern Code - N12.
Action: If a customer reports a concern of a rattle/clicking noise from the front of the engine, carry out the Service Instruction outlined below.
PARTS:
LR051008 Timing chain tensioner Quantity: 2
LR051013 Timing chain tensioner lever Quantity: 2
TOOLS:
No Tools Required
WARRANTY:
NOTE: Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to TOPIx to obtain the latest repair time.
NOTE: DDW requires the use of causal part numbers. Labor only claims must show the causal part number with a quantity of zero.
DESCRIPTION SRO TIME (HOURS) CONDITION CODE CAUSAL PART
Timing chain tensioners and tensioner levers - Discovery 4/LR4 (LA) 12.65.89.34 7.8 7 LR051013
Timing chain tensioners and tensioner levers - Range Rover Sport (LS) 5.0 SC 12.65.89.34 8.5 7 LR051013
Timing chain tensioners and tensioner levers - Range Rover Sport (LS) 5.0 NA 12.65.89.34 7.9 7 LR051013
Timing chain tensioners and tensioner levers - Range Rover (LM) 5.0 SC 12.65.89.34 9.2 7 LR051013
Timing chain tensioners and tensioner levers - Range Rover (LM) 5.0 NA 12.65.89.34 9.1 7 LR051013
NOTE: Normal Warranty procedures apply.
SERVICE INSTRUCTION:
1. Install a new timing chain tensioner engine set (see TOPIx Workshop Manual, section 303-01). You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #379059 23rd Mar 2016 6:27pm
duckworthparts
Site Sponsor
nearly a 10 hour job You can paypal direct using - www.paypal.me/duckworthparts
Post #379060 23rd Mar 2016 6:28pm
thanks Dan Thumbs Up ... - .- -.
Post #379065 23rd Mar 2016 6:54pm
Stupid question , but if a 5.0 litre 2011 model is bought and is out of warranty will LR still fix this if the fault occurs or is it only warranty vehicles it applies to
Post #379067 23rd Mar 2016 7:08pm
duckworthparts
Site Sponsor
Its not a recall, so customer would pay unless under warranty i would have thought.
Looking at my part movement, doesn't look like we've ever had to do the job before. You can paypal direct using - www.paypal.me/duckworthparts
Post #379156 24th Mar 2016 10:37am
Cheers Dan 👍
Post #379158 24th Mar 2016 10:40am
somchie
Sweden
So.
The cars throws a P0016-00.
My dealer bought a new sensor, but it still shows the same error.
I guess I'll get the verdict later today Sad
BTW Thank you guys so much for your replies! Range Rover SV Autobiography LWB 5.0 S/C -17
Post #379182 24th Mar 2016 12:00pm
dhallworth
I vaguely remember reading on here that RRUK has had this issue within 5.0 and had the timing chains done on his at the dealer under warranty.
Post #379266 24th Mar 2016 10:53pm
funnyguy1
United States
My 2011 SC rattled liked a diesel when I purchased it in Aug 2014. The dealer did the chain tensioner update kit then replaced the SC snout and.....hey! it still rattles just like a diesel!! Fine when on the road but driving around town, I just slap a diesel emblem over the SC emblem.
Post #379502 26th Mar 2016 3:38pm
