![]() | Home > Maintenance & Mods (L322) > Coolant Leak |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I seem to have a very slow coolant leak, there is no puddle to be seen under the car and to top up requires only a cupful of coolant per month. The car is running fine - should I panic or just keep topping up?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Does it put the low coolant warning on or is it just low when you check it, mine likes to run low, it never has much in the expansion tank but the level seems to just stay there...low.... If I top it up it just drops again after a while, back to where it likes to be.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Could be a hose weeping somewhere and evaporating off the engine. It's seems unlikely to be the head gasket if you have no other symptoms.
Thanks guys,
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Mine (petrol) is leaking at the seam in the header tank. I have a new tank on order.
i know there is another thread on coolant leaking from a TDV8 but mines a petrol. There is nothing on the drive or under the car that I can see but I think maybe the leak is getting worse - took a pint this morning to get level up to cold fill mark.
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Hi,
Also worth checking the bleed valves (admittedly my only experience is on the TD6) but one of mine was blowing hidden away under the engine covers. Sealed it up with hylomars and a new rubber washer and have been good to go since. .
