Home > In Car Electronics (L322) > Cd player
Markjohns1
Cd player
Hi chaps hoping a quick fix just purchased a cd cartridge for cd player in glove box but system saying no cd loaded when obvisiously cartrigde is full and cd s in face up,any suggestions ascartrige obviously fits,its a 2004 vogue petrol if that helps and cd motor makes a noise when cartridge enters so appears to be pwer to unit ,cheers cant be the first to have this glitch so advise appreciated
Post #379044 23rd Mar 2016 5:03pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Honestly, hit it with a hammer or the rubber shaft if squeamish, , see if that works.
Think I've got a cd carrier in the garage if you need one Thumbs Up
Post #379045 23rd Mar 2016 5:22pm
Try the CDs the other way up? Whistle There is nothing that can't be fixed with a hammer😜😜
Post #379076 23rd Mar 2016 8:09pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
had same problem a good blow out with airline sorted hope it helps 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #379082 23rd Mar 2016 8:41pm
Markjohns1
Probably damage dash if try and hit with a hammer as well concealed in dash,although sorely tempted,wil have a look in day light and let you guys know outcome.tried cds other way up and no joy,thanks for input other suggestions welcome
Post #379090 23rd Mar 2016 9:41pm
Discotigger
As NMJ says, put the cds face down, i.e. the face that has no writing on it should be face down in the cartridge.
Also, check the cd format is correct.
Post #379096 23rd Mar 2016 10:04pm
Markjohns1
Cd Format ? Apologies for being clueless
Post #379103 23rd Mar 2016 10:44pm
Does it cycle the discs if you select a different disc?
If so it could be a dirty laser or duff disc motor mechanism, as said, a good blow out could sort it out. You can buy cans of Air duster from many plumbers merchants Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #379106 23rd Mar 2016 11:13pm
johnboyairey
meaning -if you burnt your own cd in a pc etc, might not be read by cd player, however shop bought cd's should be tried first.
Post #379137 24th Mar 2016 8:29am
