Home > Technical (L322) > Transmission Problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Anywhere from low on oil, cheap fix, to new box, £1,500...
6th Mar 2016 4:28pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I recon that'll be a job, and it will need a rebuild Yesterday I couldn't spell Engineer... Today I are one!
6th Mar 2016 5:31pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
i have to agree i'm afraid sounds like its a rebuild or a new box, expensive either way.
6th Mar 2016 5:43pm |
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 |
I will hopefully know by COB tomorrow what the problem & proposed solution is when I will post an update. I just spent £300 having a squib replaced as the Airbag light was staying on and it would have failed the pending MOT. |
6th Mar 2016 6:33pm |
UPDATE
8th Mar 2016 3:41pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Sorry to be negative sir... But they normally will drive again when they are cold for about 200-300 meters... |
8th Mar 2016 3:43pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
As ctc's reply, mine was slipping really bad, but after a while waiting for b/down truck it drove on no problem.
8th Mar 2016 6:17pm |
UPDATE: I drove the RR to a gear box specialist and they confirmed the worst - gear box needs to be stripped & repaired @ £1,900 plus VAT! On the plus side I was able to drive the RR for about 100 miles before I left it with the garage. They said that gear boxes in my RR tend to go between 90k - 120k. I drove into the garage forecourt as the clock turned 141k. When I pick it up after Easter I'll provide a further update. Whatever happened to the days when hi spec vehicles could be relied upon to do 250k - 300k miles before they'd collapse - especially in an RR!
24th Mar 2016 9:00am |
One simple answer to your last question.... Profit.... Pete
24th Mar 2016 10:11am |
Profit........ possibly...... Reckon that "I don't give a , cos we've sold the company" came in to it Yesterday I couldn't spell Engineer... Today I are one!
24th Mar 2016 10:50am |
Im sorry chaps but........... I don’t agree, that gearbox is used I’m many different cars and fails in all of them! NOT JLR’s fault and certainly not the poor old RR’s fault
24th Mar 2016 11:08am |
But Why did they agree to a gearbox that's rated at 350 Nms max with an engine that produces 390 Nms, it just doesn't compute, especially when you look at the vehicle weight spec's for the box... I believe that the Range Rover is 0.6 tons too heavy... basically it's not fit for purpose.. if I had brought the car from new I reckon I'd be talking to a lawyer by now..
25th Mar 2016 2:00am |
Apparently the gearbox is actually a General Motors box which is fitted and delivered by BMW under licence? I will find out the the precise detail on that when I collect the RR.
25th Mar 2016 1:25pm |
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 |
I think you will find it was made under licence by Cadburys ! |
25th Mar 2016 2:13pm |
