![]() | Home > Maintenance & Mods (L322) > 2004 Brake Shield Fixable? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
few suggestions here,
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Very simple if I remember , look round the back of the shield and see the bolts just remove the bolt and put a big penny washer on it and re-fasten . 2008 MY Supercharged
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Thanks guys, I will pop the wheel off and dig out some washers! Tom
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Even easier, rip the rest of it off and throw it in the bin..... first thing I do to all my off roaders, makes no difference to the braking ability and to me is nothing but a win win situation..
Interesting point and something I will do if I cannot secure it easily with a washer, a lot of people on various forums say the shields don't really do much (many cars don't have them from factory) and surely if the disc is better protected with it then it should have a shield on both sides! Tom
| Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138
A well timed post. I have had problems with mine and after reading above (and a quick google) it seems they are really surplus to requirements so I will simply not replace them when I put the new disks and pads on. Also, therefore saving myself quite a bit as they are not cheap! |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Not only are they not cheap but they're a pain in the ass to replace as the entire hub has to be stripped off to change them |
All bolt fixing areas were totally shot and it looked like a complete pain even to add washers so I just tin snipped it off and now there is no rattle. Will do the other wheels as and when they need it. Tom
You can't remove the rears on an FF, the shield is the backing for the handbrake shoes, they rust out to and are NOT a DIY job to change, you need the driveshafts out and the hub apart, chances are it will destroy the bearing and you need a special tool to get the drivshaft back in... |
Good to know Pete. Fingers crossed they have some life left in them.
| All times are GMT |
