![]() | Home > Technical (L322) > 03 oil filter vibration |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Not sure if this is relevant or even if we have one but read this on meeknet M62 site.
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
hi thanks for the reply. vibration def coming from filter housing its not doing it all the time and goes away.i use mann filters and i cant see why it would vibrate a bit annoying thanks again richard |
Have you checked the rubber mounts on the filter housing are not split as that is a very common problem? |
hi why would it vibrate intermittently? filter housing seems pretty solid . quite bad at 2500 revs . |
can you get somebody to rev it while you have your head under the bonnet and put your hand on it to dampen it or use an electronic stethoscope / ear to a screw driver ( the blunt end) ?
oil filter def vibrating mounts seem ok. seems to start when turning steering left. had her out all day today no sign until we got home and left her an hour then started again really annoying the whole oil filter housing is rattling but is fixed solid |
And it stops the noise when you put your hand on the filter housing ?
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
The rubber socket at the bottom could be perished/gone. Worth a check. |
noise stays even with hand on filter will check rubber mount on bottom seems to only do it when accelerating but no noticeable change in performance |
When you change the filter, is the filter clipped to the cap when you remove it? |
will have a look. i have ordered new mounts and will change when they com. i was thinking along the same lines that the filter is turning in housing but i think that would be hard as the filter went in pretty tight |
I think there is supposed to be a valve in the bottom of the filter housing that the filter pushes closed and when the filter comes out attached to the lid it opens the valve so you could check the condition of the valve. It also stops the drain back from the housing when engine is off.
checked top housing today .both housing bolts have no rubber on them at all. just steel tubes linking bracket to filter / there is no evidence of rubber ever being there/ i know it would make sense to have rubber mounts. there is one on the bottom of filter/ had her out today 40 miles no noise at all running like a dream cant make sense of it has anyone else seen mounts that have no rubber on them or has mine been modified ? i have had her 3 years now and have been under bonnet lots of times/ never noticed rubber mounts on oil filter/ how would you check valve? filter fits tight to bottom of housing and would be very hard to fit if mounted in lid first. as in impossible to turn without destroying filter. will fit rubber mounts when they come and post result |
Thats cool, they have obviously broken in the past and somebody has 'fixed' them as when the rubber goes there is nothing to hold the filter body in place. They usually get old and brittle and then the twisting motion of undoing the filter cap breaks them off.
