| So it looks entirley doable, assuming you are still using factory parts.
 While I was messing around with trying to seal up the invisible crack in the aluminum valve stem I made the leak a little worse, to the point that I was having to add air everyday to keep the light from coming on.
 I see it appears common for people to replace the TPMS with a standard rubber valve stem.  I'm an instrumentation guy and I like the lazy factor of having a working TPMS.
 So I took it to a local shop who charged a bit more than I wanted to spend ($135 US) for parts & labor for 1 TPMS.  I asked them to keep my parts so I could investigate/have spare if the valve stem could be replaced.
 I've tried to attached two photos, one of the replacement, which uses a rubber stem.  I suppose less likely to corrode, but unlike the rest of my valve stems and not as cool looking
  The other photo is of the parts of the TPMS after I disassembled them.
       |  |     | Click image to enlarge |
 I should also note that my TPMS was not held in by anything other than the 12mm nut on the outside of the wheel.  So when you air down the tire and pull off the 12mm retaining nut...the TPMS may fall into the wheel/tire.
