Home > Technical (L322) > Juddering and cold start issue
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
Hi I am getting a judder between 30-50mph on my 02 td6, I have looked through the history and can't find any evidence the gearbox oil has been changed. I'm now approaching 145k miles, is it worth changing the gearbox oil or should I just have a new torque converter fitted ?
Also when I start it from cold it runs quite lumpy for a few minutes, could this be an injector problem which could also be causing the judder as above ? Guess it's getting to that time when things start going wrong, would like to keep the range so need to get these problems sorted sooner rather than later before more damage is caused. Any help or advice would be greatly appreciated
Post #379570 27th Mar 2016 7:58am
Yes, No, Maybe, Maybe.... Very Happy
Change the gearbox oil - see how it goes, if the TC is "gone" likely the gearbox won't be far behind - it has done well if it is the original at 145K (but I doubt it, normally the gearbox lasts @ 80K)
Does the car start immediately on turnover or does it take a few turns to start up? If the latter this normally points to injectors. You will need to do a leak test to identify which injectors are causing the problem, then replace them (easier said than done) .
Post #379585 27th Mar 2016 10:31am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
My gearbox went at 137k which is a good innings. When mine went it was pretty sudden with a bit of juddering and then into limp mode.
FYI You should always change the gearbox oil every 60k to keep an eye on any break up in the TC. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #379613 27th Mar 2016 12:38pm
