Home > Technical (L322) > known problems of a 2012 TDV8
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
Im n my way to sell my 2005 and buy a low milage 2012 TDV8. I like to know if the car has known problems or recalls. I like to make sure the LR dealer will take care before delivery of the car. Thank you ver much
Post #379589 27th Mar 2016 11:00am
The secondary turbo drain is one to check
http://www.fullfatrr.com/forum/topic33596.html
Post #379592 27th Mar 2016 11:17am
capcgn
Thank you, I was already aware of this problem.
Post #379593 27th Mar 2016 11:21am
If you have a specific car in mind, then you can check whether there were any recalls for it & then check that the work was done
http://www.vindecoderz.com
Post #379594 27th Mar 2016 11:31am
capcgn
Thank you, I will do so
Post #379595 27th Mar 2016 11:33am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I don't know if it available in your country but we can look up http://www.dft.gov.uk/vosa/apps/recalls/default.asp?tx When we bought our 2012 in December, the dealer was happy to provide service record and build sheet.
Post #379624 27th Mar 2016 1:57pm
dhallworth
We reported smoke on heavy acceleration to Taggarts in Glasgow on three separate occasions and on every visit they've said they can't replicate the fault so don't want to know.
When we booked the AB into Team Valley for service and MOT this year they've said straight away what it needs and they're going to get in touch with Land Rover.
Is it really an engine out job to have the work done?
Post #379637 27th Mar 2016 3:00pm
CS
There was a brake hose recall PO54 done in summer of 2015 in UK.
Corrosion seems a feature - based on my experience you might like to check:
- upper tailgate, especially bottom beside seam;
- rear wheel arches;
- upper tailgate struts;
- lower tailgate support cables;
- black trim strips around windows and doors;
- wheels and wheel centres.
The rear brakes can be prone to seizure, at this age overhaul should be enough, rather than replacement.
I've had a couple of battery drain problems, caused by software problems with (a) locking and (b) fuel burning heater. These occurred at random so could not readily be checked for.
I also had some build problems, buzzing /rattling from dashboard, door seals not fitted properly leading to leak at top of one rear door and new seal required at bottom of rear door, leak of gear oil from join to engine (new gearbox fitted due to scale of fluid loss). Only Range Rovers since 1988
Post #379639 27th Mar 2016 3:06pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Bottom lip of upper tail-gate potential corrosion weak point. Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #379646 27th Mar 2016 3:32pm
capcgn
Thank you for all the tips.
Post #379722 28th Mar 2016 9:04am
GraemeS
Australia
David.
If you're referring to the updated secondary turbo drain fix then no, it does not have to be engine out. The TSB shows the steps involved and mine was done as per the TSB, taking 8+ hours.
Post #379868 29th Mar 2016 4:37am
pld118
The car can feel intermittently hesitant at constant motorway speeds. Apparently there is a TSB and the issue can be resolved via software upgrade.
Post #379870 29th Mar 2016 7:52am
dhallworth
I spoke to Land Rover this week as Team Valley couldn't authorise the work as our car is out of warranty but Land Rover have just agreed to do this modification whilst it's in for a service as it's only done 11k miles and was reported to Taggarts in Glasgow 3 times whilst it was under warranty.
It's not going near the dealer in Glasgow again now.
Post #380360 1st Apr 2016 6:45pm
