![]() | Home > Technical (L322) > 2012 tdv8 problem |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
DOH Here not hear 2015 4.4 AB
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Slightly off thread, but wondering how big a problem it is if left unmodified.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Our car is out of warranty but Land Rover have just agreed to do this modification whilst it's in for a service as it's only done 11k miles and was reported to Taggarts in Glasgow 3 times whilst it was under warranty.
Thanks David 2015 4.4 AB
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2749 ![]() ![]() |
The problem only occurs if the engine is lightly loaded for long enough for significant oil to accumulate in the secondary inlet tract. However with the torque available low in the rev range these engines often don't get a good regular work-out so are prone to accumulating the oil. Regularly getting revs above 2500 rpm with reasonable throttle openings to get the secondary turbo operating clears any small accumulation. |
Hi, what are the symptoms/ how to tell if ours is afflicted please?
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 ![]() ![]() ![]() |
And is there a modification / campaign reference number to check vehicle history with dealers at all? |
