Home > In Car Electronics (L322) > Which reversing camera have people bought from Ebay
RSWilson
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi Guys,
I've read quite a bit on here about people fitting reverse cameras to L322's.
I bought a unit from Ebay the other day but when I've unscrewed the number plate light assembly to fit this in it is obvious it won't fit without butchering the original panel which isn't something I really want to do.
What cameras have other people bought from Ebay to view the rear/towbar (so at 45 degrees)?
I'm sure this is a well trodden path and any photo's would be useful as to how others have overcome the challenge of type and position of the camera?
Many Thanks
Richard
Post #380531 3rd Apr 2016 2:45pm
can you fill in your car profile so we know what you have please.. ... - .- -.
Post #380537 3rd Apr 2016 4:05pm
RSWilson
Hi, my profile seems to have all my vehicle details in it already. I'm not sure where this would display.
My car is a 2004 TD6 L322.
Many thanks
Richard
Post #380545 3rd Apr 2016 5:13pm
If you go to Profile then to My Range Rover Profile and fill it in it will give you a little car in the side box, hover over the car with the cursor and up pop your details... Thumbs Up Pete
-Click here for Thread-
Post #380559 3rd Apr 2016 6:35pm
RSWilson
Got it !!!
Thank you, I'd filled it all in except colour and it wouldn't let me select a colour despite having filled the rest in. I tried it in Firefox and it worked.
Thanks!
Post #380569 3rd Apr 2016 6:57pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
tbh I must say had a problem filling out my details and cant seem to find out how to change colour deatails on car 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #380570 3rd Apr 2016 7:02pm
Yeah, I'm using chrome on this laptop and it won't let me change my colour... Firefox seems to work though...!!! Pete
Post #380572 3rd Apr 2016 7:06pm
boatsandy1966
dam I'm Censored then bit new to this puter larky il have to wait till grandkids explain how to get firefox ? and where to get from when there around next 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #380631 4th Apr 2016 12:25am
p38arover
Australia
Change the year model then it will let you select the colour. The change back to the correct year and it will let you select the colour again. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #380641 4th Apr 2016 7:16am
RSWilson
Hi Folks,
Any thoughts on the best rear camera to purchase and best fitment location for the L322?
Cheers
Post #380913 5th Apr 2016 9:20pm
miggit
I have fitted 2 of these camera's to ffrr's and with a bit of trimming they work very well, plus you can see a towbar if fitted.... saves holes in the bumper Thumbs Up
They do require a bit of dremel work to the original lamp holder (cut away every thing that isn't the face) but it will work... and you'll either have to add a ballast resister or turn off the LCM for the number plate lamp.... but all in all a very neat solution, in a much better place that Land Rover fit them Thumbs Up
http://www.ebay.co.uk/itm/170-Reversing-Pa...SwT5tWNzcM Yesterday I couldn't spell Engineer... Today I are one!
Post #380932 6th Apr 2016 12:34am
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
any particular ballast resisters? gone fishin'
Post #380978 6th Apr 2016 11:37am
miggit
I used one of these on my car, http://www.ebay.co.uk/itm/2x-501-T10-W5W-W...XQs6FRNdbE
but by the time I installed the camera on my friends I had a copy of NavCoder so I was able to turn the number plate lamp monitor off in the LCM..... The Gap IID Tool will also do this... a much better solution to the resister Thumbs Up
The parts that I used for the install are as follows.....
Camera off fleabay, there are lots out there, just look for an X5 camera that looks like this
A 12v relay like this, as they are a third of the price or an automotive relay... but you need to be able to solder Shocked
And some Micro Quadlock terminals http://uk.rs-online.com/web/p/pcb-connector-contacts/7180879/
And a bit of thin wire to link the relay with the reverse lamps and the TV modual.....
The install is covered in this thread and will give a good idea of what is involved.... http://www.fullfatrr.com/forum/topic24647.html
But I have discovered that when feeding the wire through the rubber sleeve / hose from tailgate to car, it is a lot easier to just cut the plug off, as it is not required and is a right PITA to feed through if you leave the plug on Laughing Also I found that some of the 5m leads that come with the cameras have an extra red wire, this is the one to look out for as they make the wiring very easy...... connect the camera red to the red wire on the lead and the black to the tailgate which is earthed... I used one of the aerial amps / module mounting bolts as it was going in to a captive nut in the tailgate .. But check with a meter before Embarassed
Then connect the red wire at the other end to the reverse light + feed that you need to tap to switch the relay, that grounds pin 17 of the blue plug Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #380997 6th Apr 2016 4:22pm
