Home > Technical (L322) > suspension on bump stops
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
HELP
Put suspension on bumps stops to get compressor out for a small bit of surgery.
Fixed it and put it back into car, now car wont rise up to normal height.
Have iid tool . Read the manual,but its double dutch to me.
Left car running for 15 mins on fast idle to get air into tank, but still wont rise up.
What am I doing wrong .......grrrrrrrrr
Post #380637 4th Apr 2016 5:43am
Have you re-enabled the suspension with the iiD and then pressed up on the dash board switch ? 2008 MY Supercharged
Post #380638 4th Apr 2016 6:04am
littlecub
Hi axle,
Yes and it didn't do a thing.
Post #380639 4th Apr 2016 6:50am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Do you have any error codes on the system?
Any lights on the suspension selection switch?
I would check for suspension error codes, make a note if any. Clear them. Disable the suspension again if it thinks it's enabled and then re-enable - select a height.
It may not enable if there are faults on the system.
What surgery did you do? There could be an issue there.
Post #380650 4th Apr 2016 8:53am
ebajema
Have you disconnected the battery for 15 mins, reset all fault codes ?? If not, see if that makes a difference. MY 2010 5.0 SC Galway green and sand interior!!
Post #380655 4th Apr 2016 9:37am
littlecub
Wee Jock, only air susp inactive on dash
Ebajema, no haven't tried that as yet.
Did check/pull the 2 fuses( glovebox and rear),both were good.
When I put the rear back in a got a slight hiss, so something is working a bit.
Post #380656 4th Apr 2016 9:49am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hiya,
Is there pressure in the tank? Does the pump run? Is it wired up ok - (both the wiring and pipes)
Just a few things to check
cheers
Simon
Post #380658 4th Apr 2016 10:02am
Have you tried running the engine and doing a full lock to full lock with the steering wheel?
Post #380662 4th Apr 2016 10:32am
littlecub
Did the lock to lock nothing
Don't think the tank is filling up with air, cant here anything.
Post #380665 4th Apr 2016 11:07am
RP123 wrote:
Hiya,
cheers
Simon
Question Question Question
littlecub, have you done the above suggestions by Simon........
edited for clarification...... ... - .- -.
Post #380666 4th Apr 2016 11:08am
Weejock
If you have an IID tool you can check tank pressures, pump temperature etc. etc. with live data. You can also force it to run with the IID as that's how I fixed mine which was cutting out with a false over temp reading (damp in the connector). I forget how it's done on the IID but it will come under something like Actuator Tests.
Post #380759 4th Apr 2016 8:54pm
littlecub
Thanks weejock.
Post #380767 4th Apr 2016 9:29pm
Sounds to me like you haven't re-enabled the EAS with the IID....
As an aside, you can also inflate each corner or front and back as well to get it off the bump stops, this is handy if a height sensor goes out, manually fill a corner and the system switches off and just holds the air that is there...
Fix the problem and re-enable the EAS to restore... Pete
Post #380769 4th Apr 2016 9:38pm
littlecub
Pulled compressor out this morning and found that one of the smaller airlines wasn't seated properly.
Fixed it and put it back into beast and cleared codes.
Arse end started rising almost immediately, Very Happy
Took it for a test drive down back paddock.
Up mode works, back to normal then down mode doesn't. Mad
At least its silent when going up. Very Happy
But why doesn't it want to go down?
Will a battery reset fix this problem?
Post #380798 5th Apr 2016 5:52am
ebajema
Have a go with the live data see if there are anomalies showing up in the data somewhere. MY 2010 5.0 SC Galway green and sand interior!!
Post #380800 5th Apr 2016 6:52am
