![]() | Home > General > L322 v L405 dimensions |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35737 ![]() ![]() |
i've been overtaken by the L405 a few times and get the impression that its bigger than the L322 that i'm driving so i perused topix and found the dimensions of both..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8679 ![]() ![]() ![]() |
I think it's the slightly higher waist line that makes it look bigger, the Ewok looks big on it's own until you put it next to something, and I'm sure that's because it's got a very high waist line... Pete
you could be right there Pete, the L405 bonnet does look higher when next to mine.. |
With my tyres and in off road setting I can still look down an them Stan.... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1497 ![]() ![]() |
L405 looks longer cause of the higher leading edge of the bonnet makes the general body shape longer (look at the pic above in top left) . . .the bumpers are similar position, but the bonnet comes further out before cutting down. Similarly, the rear body comes further rearward at the tailgate with less of a step outwards the bumper. So the end to end dimensions are similar, but where the L322 has stepped out bumpers the L405 has less, instead replacing it with longer body panels. You're body panel wise probably gaining about 4cm rear, 4cm front, plus 3cm in overall lenth . . . adds up to at least 10cm longer in body panel along the waistline, which you would visually notice.
@Pete, when i can add those two numbers together without a calculator.. |
i'm glad i'm not the only one that thinks the L405 looks bigger.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8752 ![]() ![]() ![]() |
its all in the shape Stan,
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1411 ![]() ![]() ![]() |
The 405 is a tighter fit to get into a single garage as the mirrors don't fold in as much (2073mm as against 2034). That leaves about 1" on either side in my garage for the 405 - a bit uncomfortable. Only Range Rovers since 1988 |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Doesn't the L405 come in long wheel base option aswell. ?
yes it does Greg.. ... - .- -.
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
wow - I must be the only person that thinks the L322 "looks" bigger and has far more road presence than the 405. |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
drugs ? All my spelling errorz are belong to me!
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Size doesn't matter |
