![]() | Home > Maintenance & Mods (L322) > Dead diagnostic socket |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
That also happens on mine when I was removing the dash. Had to pull a fuse to turn them off. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
Hi NDFI,
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
Hi ndfi.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
I am ashamed to say I haven't resolved the problem unfortunately, partially compounded by the fact my car is running well and I have had no reason to date to urgently resolve the issue.
I have only just managed to download rave and look through the wiring diagrams. As far as I can see ports 4 and 5 are earths and will check them. I guess I have been lucky that every fault I have had with my ffrr some one has had before and posted the answer. Maybe this is my time to contribute.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
I wrote a post on this subject under the "electronics section". See the last post in this thread:
Thank you for the link I have watched the YouTube clip and checked the connections. Below is what I have on each port.
From my memory pin 8 should have between 3,5 and 4 volt with ignition on. I suggest you start unplugging the ecu's one by one and see if you can isolate where the fault is. ----------
A bit of an update and a cry for help. I have disconnected the abs ecu , transfer box ecu , LCM module , steering sensor and the headlamp ecu.
I have 6.35V on pin 8 with the ignition off and 8.5V with the ignition on.
