![]() | Home > Maintenance & Mods (L322) > Retrofit adaptive cruise to 4.4 tdv8 |
Not entirely sure TBH. My thoughts are whether or not the ABS pump is different. The adaptive version is capable of braking as well as holding speed. Might be worth checking if the part numbers are the same across the range. In theory they ought to be but we all know LR are capable of snatching defeat from teh jaws of victory |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Cheers, I have send Dan a PM.
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
if it can be done easily I would be up for trying it as well so let me know what you find.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2726 ![]() ![]() |
The various modulator part numbers for MY10-MY12 appear to only relate to 3 VIN ranges rather than options of various vehicles in the same VIN range, with only 1 current modulator listed per VIN range. However the ACC speed control module s/w may need to match for the same VIN range as the ABS modulator, so a s/h ACC module my need the appropriate s/w for the recipient vehicle loaded.
