![]() | Home > Maintenance & Mods (L322) > 2010/12 Taillights Issues |
| Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258
Great. So now after a fair bit of reading at other boards it looks like voltage needs to be reduced from 12v to 6v as 2010+ led taillights require 5v to work. That is why these are so bright now.
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Could you not use one of those HGV / Truck 24 to 12 droppers and then only give it 12 on the 24 side? might work... then you could use some 12 V relays to switch the lights from your 6 v supply |
Yup, I was looking at these 12 to 6 v converters. The thing is these have to be added to every line and from what I read on other forum turn signals stop working with these added. All the rest is correctly dimmed but blinkers somehow dissapear totally. 12 4.4 TDV8 Vogue
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Have you tried straightforward resistors on each line cutting the 12 to 6 Volts ? Just find a decent electric component shop and experiment a bit with them or find a good electronics specialist to sort it out for you |
Today I just ordered a set of magic boxes from super tweaks for GBP 225.
But I start to like the look, even on a dirty Buckingham Blue car:
| betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68
Just a quick note that Supertweaks is not a good company to order from.
| AzizRR Member Since: 08 Feb 2016 Location: Muharraq Posts: 54
I ordered overfinch rear spoiler and it arrived a bit late but had no issue with them.
| Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262
Ordered plenty of times from Supertweaks including my modules front and rear and not had any problems. Plenty of others have ordered from them as well. Recommend from me. |
| All times are GMT |
