Home > Maintenance & Mods (L322) > remove flip key blade?
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
after i got my new flip key from group buy, i had timpsons cut the blade, they messed it up, it didnt fit.
i ordered a Cut to code key blade online, it came today but hasnt got the bit on the end that fits it into the key case,
ive found out i need to remove the Grub pin from the old blade to release it from the part,
has anyone done this if so how i cant think of anything small enough to hit that pin out with?
thanks in advance
Post #382229 15th Apr 2016 10:01am
do you have an old set of darts lying about, they should be thin enough to knock that out. ... - .- -.
Post #382231 15th Apr 2016 10:05am
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I used a small masonry nail and a jewellers screwdriver, wd40 first though. Always better when moist...........😃 Many thanks
Paul
Post #382247 15th Apr 2016 11:43am
Ohwhatalad
no darts stan, did have some nails that were small enough tried to hammer it through with no luck, can't really hold it whilst hammering and don't have any kind of vice/grips
took it to local key shop and they didn't want to know either
Stuck once more, been trying to get this flip key done for about 2 months and seems to be a stumbling block everytime i get closer Big Cry
Post #382274 15th Apr 2016 4:50pm
Pvw10
You must have the tools so just borrow a set of mole grips then hold the key over something soft so the spring coil has somewhere to go when you hit it.
You could also place the key onto two spanners or similar ( hit the coil out between them) so it's firm when you hit it, I'm sure you have plenty of stuff Around you like this ?
Or post the thing to me I will do it for you. Many thanks
Paul
Post #382275 15th Apr 2016 4:55pm
Ohwhatalad
if i can't think of anything else paul ill take you up on posting it, i think ill cause more damage than good trying to hold it with mole grips and trying to hold a nail in the hole and hammering it, i don't think my nails are suited to the job either to be honest
Post #382278 15th Apr 2016 5:11pm
