Home > Technical (L322) > URGENT- Lost ALL ELEC POWER. Solved!!
You said battery terminals were OK, I'd take them both off and give them a good clean, doesn't take much to cause a high resistance...
Also connections to jump start terminal on bulkhead...
Good luck with it... Thumbs Up Pete
Post #382373 16th Apr 2016 12:11am
Oh for the good old days when you got a big red light come on when your dynamo/alternator packs up / drive belt falls off. Suffered the same problem on my P38A at a set of traffic lights in rush hour one sunny evening. .
Post #382390 16th Apr 2016 7:31am
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Mine did this a few times when the ignition switch went no lights or any thing when turning the key !wiggling the key as you turned it could sometimes get it to work ,
Post #382474 16th Apr 2016 4:06pm
Dolphinboy
Resolution/POWER!!!!!!
Went back with some spanners and a torch at 11pm last night. Wiggled all battery connections, etc. side repeater light was still glowing orange strangely enough. But absolutely no power to anything else including hazard lights. Crying or Very sad
So got my spanner onto the neg lead nut and started to unscrew. As I did, I touched the pole and the nut and had a little spark ....... Everything burst back to life! Got inside and interior lights are on; start ignition sequence and all lights are green go for launch Then....
Clunk. No turnover, all lights off. Big Cry
Flat battery thinks I, so back outside to remove the neg lead and come back in morning with a power pack........ Same happens again ... Spark across the neg pole and spanner.... Bursts into life again. This time it starts perfectly and I get in and drive home, arriving around midnight. Bow down went out today fora good run and she behaved like the lady she always wanted to be Whistle
Analysis - I have LPG and I think the power take off from the neg lead to the LPG system somehow caused a short or shutdown of the cars whole power system. Not sure how, but the lights on the LPG switch in the cabin were off prior to this incident. This either shorted out or caused a loose connection. Not sure how the spark/short caused it to come back to life tho?
Prize: goes to pete haylands for closest probable cause. Bow down Bow down
Post #382476 16th Apr 2016 4:51pm
