![]() | Home > Off Topic - Other Cars > Engine rebuild for 94 classic V8 |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Ivor Serle - Soham Cambridge. I have no affinity with them at all. When I worked in the industry I used them quite a few times and they are spot on. They are members of the FER and all that good stuff. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Whatever you do and with who, I would opt for, at least get the better timing chain and gears, the old are nylon, and not too good. Cheap upgrade too.
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
I've got an old 3.9 Vogue looking at sending my engine here for a rebuild.
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 143 ![]() ![]() |
Thanks both. I've used Stuart (armson) before but not recently. I need some body work too but I'm not sure he offers that. I'll ask.
If (not sure) they're still going I would always go to C&K Engineering in High Wycombe. In my youth when I used to rally Escorts, Chris used to do all my engines including a 2.6 Hart. To say the workmanship was good is like saying the Pope likes to go to church sometimes.
This lot?
Yes, they're the people. Glad to see they're still going and they'll do you proud. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1667 ![]() ![]() ![]() |
You cant get more central england than here:
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I had all the valve guides replaced by Real Steel, and they did an excellent job... I don't know if they still run a machine shop, but they are worth talking to |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2618 ![]() ![]() |
My LSE's not all that far from 200k - seems to be running fine, but I'll go 4.6 (or 5.0) if/when it does need doing - you're paying for the same bits whether you stay 4.3 or not. |
Trommel,
Ah ha Mr Ajac - the man who is the RRR forum at the moment! Droitwich isn;t too far from me so I might give them a call. Cheers. |
I think he means keep the original block, and have it as a 4.6. That would mean fitting a 4.6 crank and con rods. Pistons will be same size, sort of.
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
You can get liner slip/porous liner also on the intermediate serpentine V8 engine, talking from personal experience, I have a 94 3.9 classic, and stripped the engine many times |
