Home > Technical (L322) > fuel leak on initial start up only if left to idle
tnysctt
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
hello was wondering if any body can help my 2005 td6 on 1st start up of the day and if left to idle it drops derv onto the floor i have replaced all return pipes as it does not air lock motor runs sweet as n is reg serviced it only does this on initial 1st start of the day all other times no leak or fuel present at all any help wud be great cheers
Post #382578 17th Apr 2016 1:22pm
You will have to find where it is leaking, get it all cleaned off and dry, then lots of talc all over the area of the leak and you will clearly see where it is leaking... Thumbs Up Pete
-Click here for Thread-
Post #382613 17th Apr 2016 6:25pm
tnysctt
yep cheers n yotally agree with that its just a found it strange how it only leaks on 1st start of the day n only if ya leave it to idle for the 1st 5mins its fine then all of a suddde it leaks soon as ya drive off it stops n also no more leaks for the rest of the day even if u leav it idiling for a hr bloody strange one lol
Post #382620 17th Apr 2016 7:11pm
