![]() | Home > Technical (L322) > engine starts only with gear in neutral position ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Welcome aboard!
gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18 ![]() ![]() ![]() |
thanks for your help.
There are a thousand things that could cause "Trans Failsafe Mode" but yours is clearly related to the gearshift!
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
I got this message a couple of times on my old car cleaned and greased the selector rod - problem solved |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
It would be worth checking the alignment of the shift cable. If the selector position doesn't match what the the transmission is seeing it could cause many of these faults.
And lubricate the above.... |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
+1 ^ The shift cable is out of adjustment at the gearbox end and lubricate. |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
I have had similar on a non-RR.
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
Check your Inhibitor Switch or XYZ switch.Im on my second one and the symptoms are exactly as yours. |
thank you Rathbran,
It "inhibits" you or stops you from starting the vehicle in gear on an automatic gearbox.If you look underneath the vehicle at the gearbox you will see it and how exposed it is to the elements.Mine just went bad after approx 6-7 years and I have put a second one in .Its not too bad of a job and you can see the instructions in the online manuals in the wiki
