![]() | Home > Technical (L322) > TDV8 broken down today- Major Oil Leak- Possible Turbo? |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Perhaps silly question but are there any faults logged? You'd hope so, if there are then it might help narrow down what happened.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
Downpipe and boost hoses off first, see it it has blown the seals and ether are swimming in oil |
Jenks Member Since: 04 Apr 2012 Location: Edinburgh Scotland Posts: 44 ![]() |
No not a silly question and garage next door to me will do a diagnostic check tomorrow as she won't turn over now so best to see what's happening, however his diagnostics equipment may not pick everything up.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I take it you mean 160,000 miles. If so watching with interest as mine has similar.
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Hoping for the best of luck for you bud, mine did similar trick just into new year, approx 3.5k in parts another 2k in labour, ended up with 2 turbos, 2 EGR valves, inter cooler, power steering cooler, thermostat housing plus assorted gaskets, not the best start to new year. Had it back 6 odd weeks, front screen cracked, finding it hard to feel the love at the moment |
I'm afraid it worse than that....engine failure!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I feel for you, that's rotten luck |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
Jenks,
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
Oh dear, sorry to hear your news. Any reason given as to what caused it?
I don't understand why they spontaneously fail, is it bearing or oil pump related like the 3.0lt tdv6? It's the same family of motor, different factory. ______________________________
STOP!!! Are you sure its NOT just hydrolocked on its own oil sir??? ![]() We have had several that have! Will drain over a week or so back past the rings and allow the engine to turn over once again... Worth checking first sir ![]() |
Craig
Ahem, my name is Craig sir |
Fixed. 👍 ______________________________
