![]() | Home > Off Topic - Other Cars > 3.9 RR Classic efi auto wont start |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
sounds like fuelling to start with. you have some voltage at coil, this could be better, and maybe via the ballast resistor etc.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
^^ wot he said, plus if your battery is slightly flat then it could be causing no end of issues as most of the ignition system will cease to work at 9 volts, and you are rather close to that figure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
John, Sorry, have to disagree with your method of easy start with one of them, if you spray it in, then refit the hose, walk round to the drivers seat and try to start the easy start will more than likely backfire, destroying the MAF and the airbox... better to get it cranking and get someone else to do a couple of squirts while air is being drawn into the engine...
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I've had the hall effect sensor fail in the distributor.........
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Thanks for the input gents.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
I would agree with that, got said in the first post you only got a single spark on cranking, if be wanting to know where the others went... And as above, you may have enough battery to charge the coil initially before cranking for the first spark , but once it's turning the battery voltage drops quickly and no more spark. V8 or else ... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
I personally would start with the battery, as it sounds as if it needs doing as a matter course if the corner has lifted.
Brand new battery now fitted - no change I'm afraid.
wouldn't have thought it would, as the alternator wouldn't be pushing anything out at cranking speeds, would need the engine running to produce any significant voltage.
Cheers NMJ and all.
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 118 ![]() ![]() ![]() |
There have been stories of caps and rotors failing after very few miles so i would check these again.
I note you have changed the distributor /rotor arm.....
